Test Equip Allowed?
Not quite a radio, but it is over 62 years old? Have received a Heathkit model TC-1 tube tester.
Meter movement is broken. Takes a 1 ma at 100 mv movement.
Any one know of a serviceable replacement source?
Hole that it fits is 3 inches. 3 5/16 H. x 3 3/4 W. scale viewing area.
If this is not in the right spot please feel free to move to proper location.
Gary
I'm not sure but the last piece of Heath gear I saw with a meter used a Weston made meter. What part of the movement is broken? You could try opening it up and repairing it but it is a delicate job.
The set screws that allow the coil movement to pivot are not able to be adjusted.
It appears that the dial side set screw is missing a point on the moving coil to allow it to be set properly in balance between the two set screws.
Thanks for the info, I'm trying to locate a suitable replacement to keep using the test set.
There are currently 1315 online users. [Complete List]
» 2 Member(s) | 1313 Guest(s)
