model 41-611
Hello Philco community!
I am brand new to this, and I've never restored anything like this before. But I have my grandmothers old Philco (41-611, cabinet style) in the garage and I want to get it working and looking beautiful again.
I just don't know where to start... any suggestions would be very helpful, as too where to begin.
thanks!
Dave
Dave,
Welcome to the Phorum! Here are a couple of links to get you started
http://www.philcoradio.com/tech/plugin.htm
http://www.antiqueradio.org/howfix.htm
If you have any specific questions about your radio feel free to ask, This is a great bunch who are willing to answer any question even nooby ones, I know I've asked some. Icon_smile
Once you rescue one...your hooked. Icon_biggrin
Glenn
Happily back in Illinois..not.
Thanks so much! I'm excited to give this a go!
Dave
Interesting, it uses the Philco "Beam of Light" record changer and a ten tube chassis, but I think that the tenth tube was a preamplifier for the phonograph pickup. The set should be very similar to a 41-285 which is like a model 41-280 but has a proper phase inverter in the audio amplifier. Do you have any experience with soldering/desoldering, replacing components, wires, etc? These sets used rubber covered wire that has a habit of becoming rock hard, so once you start replacing capacitors you may disturb some of it and cause the insulation to flake off. These aren't the worst sets to work on but they are not what I would call a beginner's project, it may be worth finding some help through a local radio club if you can. I was looking in the gallery and noticed that there is only an illustration from what must be an old Philco factory catalog, but no actual photos of a real set, would you mind taking a few pictures of yours and either posting them on here or submitting them to Ron Ramirez?
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
There are currently 275 online users. [Complete List]
» 2 Member(s) | 273 Guest(s)
