Looking for info on Philco sealed cap
Went to the "bench" and found the nice cross reference to cap values in the various sealed caps for my model 19. I have one that seems to be missing from the list! It's a 8035C. A four connector (linear) counting ground. Can anyone advise the cap values and hook up?
Thanks Jerry
Hi Jerry,
My copy of the "Philco Condensers & More" book shows the diagram of the # 8035-C as follows,
The small tapered end of the bakelight block is ground ( mounting screw end), the two other lugs have separate 110 pf caps going from each of them to the ground lug. It is a dual 110pf to ground capacitor. Hope this info helps, and good luck with your restoration! Icon_thumbup
Thank you Texasrocker. Appreciate your help.
Jerry
There are currently 1407 online users. [Complete List]
» 1 Member(s) | 1406 Guest(s)
