Philco 610-121 restoration or repair
I'm going to start on my first pre-1940 Philco--a 610 Code 121. Any thoughts, precautions, hints, warnings, sympathy?
Ernie Sibberson
Firelands Vintage Radios
http://www.firelandsradios.com
Nothing special - just the typical replace all capacitors and electrolytics. Re-build any bakelite block caps and metal can caps.
Check all resistors for out of tolerance values (+/-20%) and replace as needed.
Check all RF and OSC coils for continutiy - also IF and AF transformer windings.
Check bandswitch contacts and clean if needed.
Then do your dim-bulb or vaiac tests.
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
