philco model 91 speakers
can anyone tell me if the speakers in the model 91 of 1932 are the same as the speakers in the 15 x-------------thanks
i should have said model 91 x speakers
Are the output tubes of both radios the same?
(04-21-2012, 07:01 PM)tab10672 Wrote:  Are the output tubes of both radios the same?
both of the rsdios use two 42 tubes
As long as they are the same physical size they should work because the OT pri matches the plate imp of the output tubes.
(04-21-2012, 07:14 PM)tab10672 Wrote:  As long as they are the same physical size they should work because the OT pri matches the plate imp of the output tubes.
anyone know if these radios used the same size speakers. i cannot measure the 91 x speakers before purchase -------------many thanks
I just looked...models 15X and 91X do indeed use the same speakers, K-12 (8 inch) and H-7 (10-1/2 inch).
(04-24-2012, 07:29 PM)Ron Ramirez Wrote:  I just looked...models 15X and 91X do indeed use the same speakers, K-12 (8 inch) and H-7 (10-1/2 inch).
thanks Ron--------------- thats a big help i thought they looked the same from the pictures but wasnt sure.
The transformer may be the last cause of voltage drop. This level of voltage drop is not too big. Conduct additional te...Vlad95 — 07:16 PM
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
There are currently 251 online users. [Complete List]
» 1 Member(s) | 250 Guest(s)
