My 39-45 bandswitch had been neutered
Literally neutered. Icon_eek Both balls that provide the detent action are gone. The part that they go on to is still there. Anybody know what I can use for a replacement?
Odd set, almost all of the rubber wiring is in very good shape. I had to replace the 2 wires to the pilot lamp and rebuild its base and one of the dial lamps base (the other had been replaced). replaced 2 of the 3 filter caps that had been changed in the 60's and 2 .01 papers as I was working in that spot. ( and yes I will change the others) but the thing is playing like new.
John
Las Vegas, NV USA
I don't know how the switch looks, but in many switches using spring-and-ball detention, those balls are usually the same as those in some ball bearings, so if this is it, then you could get a ball bearing, get balls from there, and get your switch all...ballsy again.
A junker bandswitch from any radio, of the same general size switch, regardless of contact/wafer arrangement should provide the detent balls.
Browse your local swapmeets...
Chuck
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
Value of capacitor
OP is "original poster"klondike98 — 11:05 PM
There are currently 1800 online users. [Complete List]
» 2 Member(s) | 1798 Guest(s)
