Philco 49-1606 AM/FM/phono console
I found this Philco 49-1606 AM/FM/record player console buried in a pile of stuff at a closed TV shop and was able to buy it for a reasonable price.
The main thing that attracted me to this model was the dual tonearm record changer. One tonearm plays 78's and the lighter tonearm plays LP's. I wish it would play 45's; but, it will be easy enough to use a Y-adapter and plug in one of those RCA 45 rpm attachments.
I've not done anything, other than examine the inside of the radio. It is a power transformer-less set that uses two selenium rectifiers in a voltage doubler configuration.
I figure this will be a decent performing unit once I get it restored.
[Image: http://i538.photobucket.com/albums/ff341...c50ea9.jpg]
[Image: http://i538.photobucket.com/albums/ff341...03527a.jpg]
It's a cool modern look. The book matched mahogany crotch veneer is striking.
Philco 40-120C Restoration
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
There are currently 2509 online users. [Complete List]
» 1 Member(s) | 2508 Guest(s)
