52 transitone no reception all of a sudden
Hey Gang,
My 52-541 transitone has been playing really good lately, I had it on for about four hours yesterday, it all of a sudden went to loud static. no reception anywhere, volume control does work, and will silence the static.
I tried all new tubes, checked antenna connections, looked underneath for loose conections, nothin.... I unsoldered the oscillator transformer, and both IF xfmr's, all ohmed out to within .2 ohms of spec. put it back together its working...... Its been playing on the bench for the last three hours.Icon_crazy...anyone have any suggestions? is one of the xfmrs opening up intermittantly?
[Image: http://i818.photobucket.com/albums/zz105...4404c8.gif]
Bad caps in the IF transformers will do that. You can troubleshoot it with the use of a signal tracer. Check for the static on either end of the IF transformers.
terry,
I dont have a signal tracer, yet, I'll be lookin around for one though. Are there any other tests I can do, other than just replacement?
I did open up the IF cans, very delicate stuff in there, those internal caps are very simple, and exposed to the air. It looks like a piece of paper riveted between the plastic housings. If were to replace them, what should I go with? silver mica?? What pF?
BTW the stupid thing is still playing this evening, about seven hours now....
Well if you just want to replace them they are around 100-120mmfd sm. Chop out the old and solder in the new. You will need to align the IF after replacement. Should have a good sharp peak with the proper cap. Don't know of another test for them other than listening to them.
Hard to troubleshoot or speculate when it is working. Could have been just a bad solder joint and you "fixed" it.
Jerry
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
There are currently 741 online users. [Complete List]
» 1 Member(s) | 740 Guest(s)
