Philco H-1 Lamp
I am restoring a Philco 41-629 Beam of Light phono and need to know what type of neon lamp was used in the H-1 recorder unit.
Also will need to know where to get them.
Thanks in advance foor any help.
The Philco part number is 34-2432, probably not much help. They are 105-125 volt. Here is a pic of the ones in mine. (I have a 41-629).
[Image: http://i266.photobucket.com/albums/ii273...97cc23.jpg]
Thanks Marv,
One of mine is broken and they are so corroded I couldn't read them.
Will keep looking for one.
Could this work as a replacement? If so perhaps you could find a different vendor that would sell only one or two.
[Image: http://i266.photobucket.com/albums/ii273...e458d.jpeg]
I believe that will work fine. Same voltage specs and electrode shape.
Dbl contact base and all.
Chuck
Thanks Marv and Chuck.
This looks like what I need.
about half the price thru amazon 10 pack $28.96 + 5$ shipping est
http://www.amazon.com/Miniature-Neon-Ind...B0086AOBQU
I think these will work for replacement for a old Distributor testing machine I have! Thanks for the info!
Also available here.
[Image: http://i266.photobucket.com/albums/ii273...f04a4.jpeg]
EdHolland. Glad you liked it. Thanks for the supportRadioSvit — 05:24 PM
Great stuff, Peter thank you for posting.EdHolland — 04:06 PM
My Philco 37-116 Restore
The crack goes from almost the bottom of the tube to well past the fat part. It is an ST type tube. The filament is open...dconant — 10:04 AM
Where is the crack? A cracked tube that has air inside will turn opaque once turned on. Perhaps it is a scratch, nogt a...morzh — 09:50 AM
I found I have a cracked 6J5 (AVC) tube. Since the tube shields are so tight I must have broke the tube putting the shie...dconant — 05:32 PM
Looks like I made a mistake. I painted my tube shields silver. Now the reception is poor and can't really zero in on mos...dconant — 01:10 PM
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
There are currently 1009 online users. [Complete List]
» 1 Member(s) | 1008 Guest(s)
