speaker wire
Does anyone know of another source of vintage cloth covered 2 conductor speaker wire? AES is kinda high esp with shipping and Radio Daze is out of stock. This is for an external speaker for an early battery set.
You might try Mark Oppat at http://www.oldradioparts.net/ . I do not know if he definitely has the wire you seek, but it is certainly worth a try. I'm not aware of anyone else.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
