can anyone identify this model
            Any help identifying this model? It has a small red light in the front and two hidden toggle switches. No sticker or model number that I can find. Please help!!
http://www.philcoradio.com/gallery/1940c.htm#h
But, it should have only one toggle switch under the left side of the dial, not two toggle switches!
That is one of my favorite Philco consoles. Very neat styling, and a very good performer as well, once you deal with the usual rubber-covered wiring issues.
Thanks!! It does have two toggles one right one left. It has a little red light I thought it might be a mystery control?
It should not have a toggle switch on the right; that one was added by someone after the set left the factory. Radio-phono switch, maybe?
No, the 40-201 is not a Mystery Control set.
Philco Battery-WWII vintage
Well Philco did start out in the lead acid battery manufacturing business, and I think that they were still doing so dur...Arran — 12:06 AM
It is odd that they chose the autodyne mixer/oscillator in one version of this set, with the #15 tube, but chose to use ...Arran — 11:02 PM
Information on the Other Front Runners of the Era
It's not  philco but I use it quite often for Marconi radios which are Canadian. It is just another resource for u...Dan Walker — 10:25 PM
Glad to hear the radio is back home. David :clap:David — 08:47 PM
A great ending to the H 725 saga. I would feel all warm and fuzzy. PaulPaul Philco322 — 07:13 PM
Hello everyone!  I've been working on a Philco 38 farm radio with the code 121 version chassis. As you all may know thi...Stormlord5500 — 06:36 PM
PT-6 finished!!
It’s a 1941 model. I won’t be using it enough to justify figuring out. All that’s left is getting the knob I have on or...bridkarl — 06:21 PM
PT-6 finished!!
I have heard of some people adding current limiting resistors ahead of the heater string in AC/DC sets but I never bothe...Arran — 06:16 PM
PT-6 finished!!
the bulb is acting as a current limiter. Sort of a cheap solution to save the rectifer and the power supply filter. I’...bridkarl — 05:49 PM
PT-6 finished!!
Fantastic progress so far! You bring up an interesting question regarding fusing. I don’t hear much about people fusing ...jrblasde — 05:30 PM
