49-906 FM hum
I just finished my 49-906. Replaced all caps, out of range resistors and a few tubes. Alignment was done also.
AM is good and strong-no hum. FM picks up a few stations but has a hum all across the dial. It does almost go away when tuned to a station.
What did I miss?
http://www.nostalgiaair.org/PagesByModel...013675.pdf
Eric
The Villages, FL
You might try changing the 14F8 converter tube. If it has heater to cathode leakage, then the AC voltage for the filament will FM modulate the oscillator, causing a hum. It could also be the 19T8 tube, since different diode sections are used for FM.
Thanks, I'll try a swap and let you know.
Eric
The Villages, FL
That did it! The 19T8 made a difference.
Thanks, Mondail,
Eric
The Villages, FL
First Radio restoration
There are currently 2345 online users. [Complete List]
» 1 Member(s) | 2344 Guest(s)
