Philco 512 red mandarim: flowers and bird
1) Does anyone have good photos or knows where to get them showing
the flowers painted on the front of the set and the bird on the lid?
2) Were the flowers and the bird made according to a only one pattern or were there multiples patterns? Icon_confused: Icon_exclaim
I can tell you that the patterns on the 1928 Philco painted table models were all hand-painted; thus, there will be variations in the patterns from one set to another. Nevertheless, each model followed a distinctive pattern; i.e. the painted flowers and the bird on the 512 Mandarin Red will all be very similar, but not exactly identical.
I have a Mandarin Red 512, but it is badly scratched up, so I doubt if photos of it will help you.
Hi,
I found this on-line sometime ago and perhaps it will be of some help:-
http://www.goantiques.com/scripts/images,id,900544.html
there's a pic of mine at http://www.radioatticarchives.com that may help,phil
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1261 online users. [Complete List]
» 1 Member(s) | 1260 Guest(s)
