Phono Cartridge resistance
Does anyone know what the resistance should be for the D 10-A phono cartridge? Thanks for any input.
Specifically no idea, but any working cartridge should respond a bit to stimulus of needle. Crystal or Ceramic cartridge more so, should give some response when hooked up to an amp. Magnetic cartridge would have pretty low resistance, and very small output compared to other types. Dried up cartridge with no output and seemingly infinite resistance is probably no longer good. Hope someone else can be more helpful!
Thanks, codefox... I havent finished the radio yet so I cant test it in that way. I thought someone had mentioned in the past that the cartridge hsould have a certain rsistance. if i am wrong on that then I guess I will have to wait until the radio is finished to see if the phonegraph will work. Just hopeing to get an idea in the meantime. Icon_smile
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 640 online users. [Complete List]
» 1 Member(s) | 639 Guest(s)
