Philco 47-204 Leatherette restoration
[Image: http://home.comcast.net/~morrised2006/ra...lco204.jpg]I recently acquired a Philco 47-204 which has a leatherette covering. After removing the usual paint splatters from the top of the cabinet (I picked them off carefully with an X-acto knife), I cleaned the leatherette with mineral spirits. I then easily restored the leatherette finish with brown leather scuff cover, which can be found in most shoe stores. Kiwi was the brand I used, but there are probably others.
I then masked off the leatherette and restained the upper wood trim with mahagony stain, and repainted the lower wood base trim with antique white. I then applied several coats of lacquer (to the wood trim only, not the leatherette). I repainted the knobs and speaker/dial bezel with the same paint I used for the bottom trim. The final step was to fabricate a new plastic dial cover. I used the plastic from the window of a gift box of vodka, a plywood form, and the kitchen oven to heat and form the plastic.
Electrical restoration consisted of replacing a bad tube, recapping, replacing an out-of-tolerance resististor or two, and a new power cord. The radio plays very well, with good sound.
Great job, Ed! It looks very nice.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1261 online users. [Complete List]
» 2 Member(s) | 1259 Guest(s)
