How to make a new dial cover tutorial
NICE,,,NOW ,,you can sell them,,,GREAT
Well....I still am willing to pay for Mark Palmquist's lenses vs DIM ones. At $20 shipped (I believe in Kutztown it was a bit less) for me it makes sense. He also makes glass ones. Plus the gaskets.
Sell them? NAh, IT is .50 cents in plastic.. $20.00 each is a bit crazy....
The hard part is making the form but still.
Flat-bottomed are easier. Then there are lenses, convex. Etc.
Not trying to be critical, but is anybody else having trouble following this tutorial? I really would like to try this, but I get lost at step 6 where it says: "Then attach the cutout to the center". What is the "cutout", and to the center of what? In step 5, he refers to the cutout as the piece with the hole in it (the masonite-looking material in the picture). Is this the "cutout"? Doesn't look like it in the picture associated with step 6. Why would there be a need to attach it to the "center" of the other half-inch piece of material if the two half-inch pieces are roughly the same size? Does he mean attach the "insert", which is the term he uses for the quarter-inch material (the rounded-corner rectangle) in step 5?
It gets even worse for me in step 7, "bottom of the template", "base of the template", "top of the template", "bottom half"? Maybe too many terms for the same piece, or maybe I'm reading too much into it. The tutorial looks like it has a lot of potential if I could just get through steps 6 and 7. Anybody care to clarify?
Hi Mark, welcome to the Phorum!
Icon_wave
Kirk (Oldrestorer) is on the Phorum a lot so I'm sure he'll be happy to help you figure it out.
I hope the new pics help..
Thank you for questioning it. I need feedback to make it understandable..
Let me know if there is anything else...
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
