41-290 Antenna Mounting
I'm getting close to finishing a 41-290 and need a bit of info (or some photos) showing how the rotating antenna is supposed to be installed. When I got the project, the antenna was held into the cabinet only at the bottom. It looks like it should also be secured at the top, given that there are matching holes in the antenna top block and the chassis mounting board.
I'm doing more of a functional restoration rather than being too exact about things, but would like to be somewhat close to the original.
Thanks!!!
