Silverstone 4763
Happy Weekend EverybodyIcon_biggrin
I've been working on my Silvertone for a week or so. Most of the way through recapping. Tonight I got to one of the electrolytics in the set. I removed it, and managed to hack saw all the way around the base. My problem is that the two parts won't come apart. Here is a picture:
https://flic.kr/p/no6DPa
I tried heating it with a hair dryer on high for about 10 minutes, but nothing would budge. Is this a situation where I just have to pull harder, or heat it hotter (oven? If so how high for how long?), or something else?
Thanks in advance.
I would either pull harder, or cut all the way through with the saw and use pliers to pull it out.
I wouldn't think using heat on dried up electrolytics will do much.
I've never taken one of these apart. I thought it might be filled, partially at least, with potting tar/wax like Bakelite blocks.
Not in any cans I've taken apart, which is something like half a dozen.
Typically, that style electrolytic uses a tar like material to secure the actual capacitive element inside the can. It may take considerable heat to melt the tar and free the assembly. I have used a heat gun, which produces a much higher temperature than a hair dryer.
Thanks Mondial,
Might be time to get a heat gunIcon_wink
Picked up a heat gun an hour ago. Heated the cap for 5 mins on the low setting and everything pulled out. Thanks Mondial.
I saved a crock pot that my wife did not want any more from the trash. I used it to heat the Philco 20 filter block . It worked well and you can control the heat better than using a heat gun.
I have redone a couple of the 4763 but just put the filter caps under the chassis . I sold them at NEARC swap meets. One went for $125 and two weeks later appx Eric in NY , the one that holds most radios up in the air "sold " it for $425.
Does anyone know why many of the Silvertone chassis from that era turn dark and the labels look burned? Is it just a reaction with a cadmium plating?
Henry
Radiohenry,
On mine, the chassis is rather dark, though I haven't gotten around to trying to clean it up yet. Also all of the labels on mine (both inside the chassis and outside) look burnt. I had assumed they were actually burned or overheated somehow.
In all of my previous restorations, I just disconnected the electrolytic cans and added new caps underneath. I decided to give restuffing a try this time. I'll see how it looks after I finish before I decide to do any others. It is definitely more work.
How many people restuff vs. hide underneath? Curious.
I only stuff them if it's a really rare set. I respect others who restuff everything, and I wish I had the patience to do it. It's just too tedious for me. About the only things I always stuff are bakelite blocks and my face! Icon_smile
I rarely restuff . Generally only if there is no room under the chassis. Exception is something like the Philco 20 filter block that is really easy to do and keeps that job a lot neater. On a rare occasion I will restuff the bakelite blocks but that is rare indeed.
Henry
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 587 online users. [Complete List]
» 1 Member(s) | 586 Guest(s)
