Stromberg Carlson cap ?
Hi all,
I have a Stromberg Carlson  430M console and I have started to recap and I have a couple of cap questions.
#1 c-21 I read it as  20mf @ 25v ? this is a paper cap that has 20-25 on it I looked at the print and I see a 20mf I want to replace it with a 22mf@50v electrolytic is this ok?
2# c-41 is a .005 @ 1200v   all I have is a 630v  the closest I have to this is a .01 @ 1600v should I series two of them or I'm I good with a 630v cap?
http://www.nostalgiaair.org/PagesByModel...021539.pdf
Thanks
Eric
1. This is not a paper cap, it is an electrolytic, and should be replaced with one as well. 22uF is OK.
2. I think 630V would be OK (I think it is for those radios where you could potentially unplug the speaker on-thye-fly and create overvoltage) but if you feel uneasy about it, serialize two caps of twice the capacitance 630V ea.
Here is a picture of what I call a paper cap I have never seen anything like this in my very limited experience which is why I'm questioning it I do not believe it is a electrolytic cap so what is it? The position of the cap I verified both by the wiring diagram and the schematic.
Eric
That's an electrolytic cap. At one time they were made like that in cardboard tubes. Note the + symbol at the left end in the photo.
Just never saw one like that, also the braided leads were quite different.
Thanks all
 Two .01 uf 630 vdc caps is .005 uf 1260 vdc in series, I take it this one is a tone compensation cap across the output transformer primary? The electrolytic is probably a bypass connected in parallel with the bias resistor on the audio output tube, if so then 22 uf at 20 vdc is fine, in fact you could use pretty much anything there if it's at least 20 vdc, 20 volts is sort of an odd voltage rating for a small electrolytic anyhow, sort of like finding a 1/3 watt resistor.
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
