38-5 volume problem
(12-17-2014, 07:38 PM)r8i0 Wrote:
(12-17-2014, 07:07 PM)Mike Wrote:  Welcome to phorum. Did you by chance get around to checking the grid cap leads as mentioned by Aaron?
Hi Mike
I cleaned the grid caps and the connectors and still have the problem. I Just replaced the 6f6 tubes again no solution.
Almost 30 years repairing radios and this is one of the toughest.
r8i0
It isn't just a matter of cleaning them, sometimes they need to have the joint re-soldered, the lead due to internal breakage, and the cap itself due to a deteriorating solder joint.
    Bill, you've got a lot more experience than I do so I doubt I can help much, but I feel your pain.  I've got an 84B that has a similar volume jumping around problem that I've yet to diagnose.  I've prodded for loose components; looked for cold solder joints;  cleaned dirty pots and tube pins but haven't located
[/quote]
Good evening,
Earlier today I replaced the pair of 6f6 tubes with a pair of 6v6 tubes and the problem got worse. The bounce went crazy. Big highs and low lows. I am going to concentrate on the output for now and will report the results.
R8i0
[/quote]
Well, I think that I finally found the problem. I decided to replace ALL the resistors in the radio and found that in an earlier repair they put a .01 on the grid of the 6J5 and the schematic called for a 110mmf. I replaced this cap and the radio is playing at a nice steady volume for about 30 minutes now. I'll play it for another hour or so and if it is still good I'll call it done. I will check the alignment again and then put it back in the cabinet. I will then try to send a picture of it completed.
Thanks to all who helped with this fix. Merry Christmas.
Congrats!!
110pF.....0.01uF....someone missed a few decimal points on that conversion Icon_lol  Glad you found the problem.
I wonder why the volume was bouncing....unless it was a phaseshift created by the cap since the triode is part of the AVC which is a neg. feedback so it got to oscillate....
There are currently 1924 online users. [Complete List]
» 1 Member(s) | 1923 Guest(s)
