49-901 Capacitor and coil combination missing
I am restoring a Philco 49-901. It is all original EXCEPT that C303 (in Beitmans schematic) has been replaced with a .1uf 600 volt orange drop. The schematic shows an associated coil in series with the capacitor. I recall restoring a 42-xxx Philco which also had this part. In that case I just wound the same number of turns around a new film capacitor (the original wiring was rubber and falling apart). This part is connected between B- and the chassis, in parallel with a 150K resistor.
Does this coil have any real function? If so, does anyone know how many turns of wire I should use (since the part is missing in my radio)?
Thanks
They attempted to 'tune' this bypass arrangement for the most effective bypassing at the IF frequency. Some of the older paper caps showed resonance on other frequencies because of their internal construction and didn't perform well at 455 so the goal was to tune that back down to 455.
Modern caps are not particularly known for this problem so the coil can be omitted. Unless you just want it there for looks but then you theoretically run the possibility of recreating the original problem unless you know the internal inductance of the new cap and can calculate it in accordingly. Icon_surprised
-Bill
The coil/cap in series did have a function, but can be just a cap now.
See my Service Tip: http://www.philcorepairbench.com/tips/svctip37.htm
Chuck
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
There are currently 920 online users. [Complete List]
» 4 Member(s) | 916 Guest(s)
AvatarAvatarAvatarAvatar
