grid voltages
Any one with an idea as to what g1 volts shoud be for a 650. I have distorted audio (clipped) and suspect the 78 tube is bad but G1 voltages would be a help for the whole set as well.
Dave Casazza
Keep em glowin and goin...
The reason G1 voltages aren't typically shown is that they will measure differently with different types of meters because of the loading effects.
One approach is to simply use the specs from a tube manual (or online tube data source) http://tdsl.duncanamps.com/ and you MUST use a meter with a high input resistance. Modern Digital meters or VTVMs generally fit the bill and they didn't have them back in those days.
Where there is a cathode resistor involved the cathode voltage will often tell the story but that requires that the tube be in good shape.
Could you describe your distortion a bit more? Normally neither of the 78s would account for that. Have you recapped the set ?
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
There are currently 957 online users. [Complete List]
» 4 Member(s) | 953 Guest(s)
AvatarAvatarAvatarAvatar
