Help with Cleaning Dials
My 38-5 dial plastic is pretty filthy, I assume that using some water on this to help clean off the dust and residue is safe? I'm not going to wipe off the dial markings or anything am I?
Second, the dial is discolored (darker) on part of the face, I assume this is from sun, heat, and so forth, is this reversible or is it just one of those things that happens with age and I should live with? Doesn't bother me but if there is a way to address it then I would (Short of a new dial)
John
KC0EYF
DO NOT USE WATER OR ANY CLEANER!!!
You really cannot clean them.
The inks on Philco dials is water soluable!!! You will have a FULLY cleaned dial if you do.
Great Advice Chuck. I made that mistake on my first restore. Fortunately "Radio Daze" had a replica. However I would have preferred the original....that went down my drain. Icon_cry
OK, Message recieved! Glad I asked the question.
I won't use anything to clean the dial. Thanks for the quick reply, I was getting antsy to do just that.
I knew I could count on you guys for help! Now, if I could just generate capacitors out of thin air.......and wave my hand and have them all soldered in.........*Poof*....Were you saying something??....
Thanks again.
John
PhilcoPhil Wrote:Great Advice Chuck. I made that mistake on my first restore. Fortunately "Radio Daze" had a replica. However I would have preferred the original....that went down my drain. Icon_cry
Buy one of Mark Oppat's dial scales. They replicate the original FAR more than any other. Or, several gents like Ron make their own.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
There are currently 5049 online users. [Complete List]
» 1 Member(s) | 5048 Guest(s)
