Philco 40-115
Can you tell me what kind of wood are the end pieces? Someone, in trying to refinish it, sanded across the gain leaving many visable "scratches". So I'll need to sand out the marks and restain. Could you also suggest the appropriate stain color and medium? Thanks.
David Woodward
Hi
Looks like your Philco uses cheap "white wood" for the end pieces, most likely toned Extra Dark Walnut while the main body of the set would have been toned Medium Walnut.
Tinted lacquers were used originally; these are available today as toning lacquer, in the color names mentioned above, by Mohawk. These toning lacquers produce a realistic finish, much more so than stains and varnishes ever could.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
