FM Reception 46-480
Hope all had a nice holiday weekend. I get lousy FM reception in my area. Just a couple of stations and they are somewhat fuzzy. My 46-480 picks up several stations with the antenna I made but I have to turn the volume all the way up to barely hear anything. AM stations are just fine. Can anyone shed some light on the FM? I have a modern radio that picks up the same stations but I get plenty of volume from that radio. Thanks!
Hi
Have all paper and electrolytic capacitors been replaced? Tubes checked? Set aligned? And...is the set's FM antenna connected properly?
Thanks! Yes to all of the above. Everything went smoothly. I did have a problem with the Loctal sockets after I pop-riveted them back into the chassis. The heads of the rivets wouldn't allow the tubes to seat properly. I filed the heads and cleaned all the sockets per instructions found in another post and the tubes seat well now.
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
This is what it looked like beforePlatinumblonde36 — 01:01 AM
