Philco 37-665B Restoration
#46
Could be a tube or AVC problem, or a sticky vane.
To determine if it is a mechanical or electrical problem, place a voltmeter across the leads of the shadowmeter and monitor the voltage. Should be 10 volts or more when fully open. When the vane shadow is closed there should be little or no voltage across the meter. If there is a low voltage across it but the shadow remains open then it is mechanically sticking.
#47
I tried to send some photos up but I ham-handed things:
My Philco will be home next weekend. The cabinet was completely redone. It looks like new! The price was "OUCH" but worth it as this is an heirloom. The chassis will be mated with the cabinet and adjustments made before Saturday. Nothing like having a nearly new Philco!
There are currently 1676 online users. [Complete List]
» 2 Member(s) | 1674 Guest(s)
