Cabinet problems
I was putting on the lacquer coat and I found that the lacquer was not stating in the grain of the wood. Now it looks good except for the finish on the top looks like it has open lines in the finish. HEEEELPPP on this. Icon_mad
Did you use grain filler? Sounds like you skipped that step. If you've only put on one coat of lacquer you could still fill the grain. In fact some fellows insist on doing it that way. Then apply your final coat.
RATS!!!!!!!!!!!!!!!!!!!!!!!!!!
Icon_redface
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1252 online users. [Complete List]
» 2 Member(s) | 1250 Guest(s)
