Philco Service Bulletin PR-1100
Hello all
Still working on a 46-1201(code 125); the Philco "update" bulletin posted before helps, except that I cannot find a schematic for 46-1201 (code 121) that it refers to. It does however reference Philco Service Bulletin PR-1100 as a source of this schematic. It also says "these documents should be used in conjunction with Philco Service Manual PR-1167.".
Does anyone have a copy of PR-1100 and/or PR-1167??
Thanks in advance!
theblurrrr
I need this now also. I can't tell how my phono should be wired.
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Need Help to ID this radio 11 tube Philco
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
Try a 39-116.Radioroslyn — 09:24 PM
There are currently 902 online users. [Complete List]
» 2 Member(s) | 900 Guest(s)
