Philco Console 37-61
Philco Console 37-61...Would a regular (todays) speaker work on this or does it have to be a tube amp speaker...
the original has 3 wires wound together---what would happen if a regular speaker was connected to the old wiring..I was told a regular speaker would make a loud humming noise..
Hi
The original speaker used in your Philco was an electrodynamic type, which used a field coil (electromagnet) instead of a permanent magnet, to produce a magnetic field which makes the speaker work. Of course, permanent magnets now perform that job which do not require electrical energy to produce the magnetic field.
This field coil is, often, part of the radio's power supply; specifically, it is used as a filter choke in many applications. This is the case with your 37-61.
Yes, it can be replaced with a permanent magnet speaker...but then, you also need an audio output transformer to match the audio output of the receiver to the voice coil of your replacement speaker...which will be a different value than original. In addition, you have to replace the resistance of that original field coil with something. A power resistor, 1000 ohms @ 25 watts will work as a substitute for the field coil, but you may have to increase the value of the set's electrolytic (filter) capacitors to make up for the increased hum due to the loss of the field coil.
My Philco 37-116 Restore
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
