cabinet top repair
The cabinet top of my Philco model 116 has flaking lacquer.Rest of set has a good finish.What suggestions can anyone share?
Thanks Dennis
I scraped the old lacquer off the top of a console once using a sharp knife. I gave the top a touch up coat of stain and sprayed it with new lacquer which I then knocked down a bit to make it match the rest of the cabinet.
 A 116B or a 116X? If 116B is it the early version with the shouldered cabinet or the later version with the walnut veneer top?
(05-21-2016, 03:00 AM)Arran Wrote:   A 116B or a 116X? If 116B is it the early version with the shouldered cabinet or the later version with the walnut veneer top?
 Radio is model 116-121 with shouldered cabinet. The top had toning lacquer applied with no stain visible.
Dennis
(05-20-2016, 02:42 AM)Squire Wrote:  I scraped the old lacquer off the top of a console once using a sharp knife.  I gave the top a touch up coat of stain and sprayed it with new lacquer which I then knocked down a bit to make it match the rest of the cabinet.
Squire
  Thanks for help,I will try this approach.
(05-21-2016, 06:49 PM)Up2960 Wrote:  The top had toning lacquer applied with no stain visible.
That is because Philco did not use stains on their cabinets - they used tinted lacquer to achieve the color on the wood.
Good point!  The one I did was a Silvertone not a Philco.  It came out pretty nice though!
There are currently 2529 online users. [Complete List]
» 1 Member(s) | 2528 Guest(s)
