Does anyone know about Grunow radios
Hello everyone, Yesterday I found a Grunow radio. Its model is 1151 console. It looks all there,except it does not look like the speaker in the set is original to the radio. The cabinet is ok but missing a lot of little pieces. Has anyone seen this set before? Was it a common radio to find? And how do Grunow radios play? Thanks!  Icon_e_smile
Hi John,
I took a look at the diagram for and it looks to be a good set. Containing a RF amp, separate mixer and osc tubes, one IF stage, A beat frequency osc, high gain 1st audio stage, parallel 76 driver tubes, and p/p 45's in the output. I'm a little surprised that it's using 45 tubes by 1935 they where getting long in the tooth. Also they require there own 2.5v filament winding all the others at 6.3v. If it was a Philco it would have p/p triode connected 42's. No need for the 2.5v winding. THe spkr is a little different than most in that the field coil is tapped and it's connected to the negative leg of the power supply so the resistance of the coil determines the bias for the 45's. Without the original spkr field can be replaced with a few high wattage resistor. Pray the power transformer is good for a rewind will$$. Finding one would be difficult.
Well, it's an 11 tube set so it should be a pretty decent performer.  I don't recall seeing one, but I don't look for a lot of consoles either, although I do think it is a nice looking radio.
Below are a couple of links that might help you out:
http://www.nostalgiaair.org/pagesbymodel...008334.pdf
http://www.radiomuseum.org/r/general_ho_1151.html
An original speaker might be tough to find, but you never know what will show up on eBay.  Good luck.
Thank you guys.  I will be on the look out for a speaker. The set is in the garage waiting for me to look at it. I hope its not a complicated set to recap. You do not see many Grunow radios out there! Thanks again!
Grunows of that era suffer from the same bad coils that Philcos do.  I have a model 1162 that is in pieces and have worked on a couple of model 750s.  Both models use the same coil and band switch sub assembly and they all had coils that needed to be re-wound.  The 750 is one of my favorite sets and the 1162 should be even better.
Sean
WØKPX
(05-22-2016, 09:31 AM)Sean Wrote:  Grunows of that era suffer from the same bad coils that Philcos do.  I have a model 1162 that is in pieces and have worked on a couple of model 750s.  Both models use the same coil and band switch sub assembly and they all had coils that needed to be re-wound.  The 750 is one of my favorite sets and the 1162 should be even better.
 Well not the same coils as Philcos, but they do seem to suffer from open coils much like Philcos do. Whether they fail for the same reason I do not know, the Philco coils seem to fail because of the type of plastic they chose to use as an insulator between the primary and secondary windings. Depending on whom you talk to it's either because this plastic expands and snaps the wire mechanically, or because it leaches something corrosive that eats through the wire.
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 986 online users. [Complete List]
» 2 Member(s) | 984 Guest(s)
