Philco 2670B escutcheon removal
I picked-up a Philco 2670B a while back and I need to know if there are any ideas for removing the large round escutcheon from the cabinet so that I can do some work on the cabinet. I can't see how it was ever attached. I understand it has 3 parts. I did manage to remove the Shadow Meter, but there doesn't seem to be anything there to loosen the escutcheon.
Rotate the front round part counterclockwise a couple of degrees and it will come off. Super simple.
Pete AI2V
Thanks Pete,
Quite often these things do end up very simple. Better than my trying to just pry it off.
Regards, Bob........
homebrew Wrote:Thanks Pete,
I have a nice example from someone who did exactly that! Icon_rolleyes
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
