Hallicrafters S-40A
Hi, I am restoring a basket case Hallicrafters S40A, and have discovered that the RF interstage transformer for band 1 (broadcast) has an open secondary, which is the tuned grid circuitof the 6SA7. I've checked to see if one of the solder tabs has led to a fracture of tyhe wire and it has not, so the open wire is buried in the secondary coil. Gary Brown has depleated his supply of bandswitch mid-sections of which the transformer is part. So now I contemplate winding a replacement on an Amodon Associates toroid core. Perhaps aviewer has a parted out S40A with an intact bandswitch mid-section, and if so I'd like to hear from them. Email:nq2v@arrl.net with help or suggestions.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 425 online users. [Complete List]
» 2 Member(s) | 423 Guest(s)
