Philco 46-1201 code 127
I'm looking for a schematic for this two knob set. I can find the code 122 but not the 127, and it's not listed in my Mallory encyclopedia 5th edition. The 127 uses the 50Y6 rect. and has a PM speaker. Also, I have seen a four knob version of this 'Bing Crosby' radio/phono. Any idea what the model number is on that one? Thanks, Ken
Hi Ken
My 1946-47 Philco Home Radio service manual has two pages of production changes for Model 46-1209, and an additional two pages of general information. The changes go through Code 130, and shows a partial schematic of the power supply and audio circuit of Code 127. I can scan and e-mail these to you if you wish...let me know.
I've seen a picture of the four knob version of this set somewhere. I seem to recall that was either an export model or a UK-exclusive model? I've never seen, nor do I have any info on, a domestic (USA) version of this set with more than two knobs.
Ron, I borrowed the book you mentioned to copy what I need, so I won't need your copy. thanks, Ken
Glad to hear you got it. Sorry, I haven't been around the computer as much the past couple of days.
( edited 11-30-2008 )
If anyone else needs this info, I have scanned all of the production changes to Model 46-1201 and now have it in PDF format (7 pages).
This information, along with three other downloadable files, may be found here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Hey Ron...
If you still have the production changes for the 46-1201 I'll take them...Thanks....
Please look here:
Ron..... Icon_biggrin
Thanks a Million!!!!!It really helped getting this old girl up and playing...
My Philco 37-116 Restore
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
