reception
Have a Philco 49-505 just got it. In my office, located in an office building I get top end of the dial well but at lower end a lot of static and loud pops. Again notat the top end but at the bottom. I sont see a place for an external anttena if anyone thionks that moght help. Any thoughts about a AC line filter
DAvid
You can try blowing all the old dust & debris out of the tuning condenser on the chassis. Sometimes, a dirty tuning-condenser causes the reception probs you described. Try a spray-can of air cleaner used for computers,etc. avail at walmart,etc. If the set hasnt been recapped & properly serviced & aligned, its time for your radio to get a full electronic overhaul by a qualified tech, or by help reading these forums pages to help you do it yourself. Icon_wink
or it could be the fact that you are inside of an ' office building' full of interference.
Take the radio home and see how it works.
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 1657 online users. [Complete List]
» 1 Member(s) | 1656 Guest(s)
