Philco PT-93
I have a question about the candohm resitor #27A/B 40 ohm and 80 ohm. I need to replace it because one side is open and the other is out of tolerance. Can I just put a terminal strip in place of it with a couple of 5 watt ceramic resistors? Philco PT-93
Yes 5W resistors will work fine. Make sure they do not touch wires - they still will be pretty hot.
There are currently 1965 online users. [Complete List]
» 2 Member(s) | 1963 Guest(s)
