41-295 I.F. Transformer Caps Missing
http://www.nostalgiaair.org/PagesByModel...013423.pdf
Have the 3rd I.F. can, part #42 open. Suspected open coil, but it is OK. Schematic shows two 100mmfd caps inside, #'s 42A and 42B, and #42C, a 47K resistor. The resistor is there but no caps.The black wire that grounds the two caps just dead-ends at pin. Does anyone know if this was a production change? If so, why did they leave the wire ? 99% sure radio left factory like this. I don't know enough to determine what  effect  this would have on circuit.
The 100 pF caps are built into the white ceramic piece at the top of the IF transformer, so they are not visible.
OK,thanks. Curious. Are they under the variable or actually cast into the ceramic?
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
