nice,simple 2-tube compressor schematic:
I found I needed a compressor to keep all my various CDs output levels the same at the input of my homebrew LPAM transmitter. By adding this simple compressor, allows me to run full 100% modulation from my LPAM xmitter, without having to make input adjustments from various CDs recorded output levels.
I found a nice-simple schematic online that works very well! Thought I would share it here. Most vintage radio restorers/techs will have the parts needed for this project onhand in your scrapboxes. The ac trans is not shown in the schematic, but ( adding it),..is simple to understand. I used a small ac trans with 117-125 v primary, and 150-ct-150 hv secondary, with a 6.3 volt tap for filaments supply.AC trans HV rect c.t. goes to chassis ground. Rectification is via (2) 1N-4007 diodes + to tubes plates via 1 connection point from trans h.v. leads. AC hum is filtered via a 100uf/ 350 v cap at B+ to chassis gnd.
As for the variable-resistors, I used a spare 1-M audio taper, & for the 25k, I used a good spare linear taper. It works well.
The 10uf electrolytic in the schematic , I used a spare 350v type. I used new carbon/comp 1/4 watt resistors throughout, and added a couple used 1/4 in female switchcraft connectors for hookup.
Heres the very simple 2-tube compressor schematic: ( many other good schemats at this site also!)
http://www.triodeel.com/comp1.jpg
Icon_wink
Well, never enough yet how much is too much? I ordered some spare parts from a couple vendors in China and now have ship...TV MAN — 10:49 AM
This Marconi was a bit of a challenge. It was totally missing one electrolytic  capacitor, and the photos show a couple ...Dan Walker — 10:48 AM
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 1143 online users. [Complete List]
» 1 Member(s) | 1142 Guest(s)
