Threads: 85
City: Annapolis, IL
State, Province, Country: USA
Same here. Very nice. Now, I gotta do an alignment and try this baby out!
Tim
Threads: 114
City: Sneedville, TN
I made the tool I use from a piece of 1/16 inch brass rod. Cut it about 6 inches long, bent over one end about 1 inch from the end to make a handle, ground the other end to a screwdriver point. To insulate just used heat shrink a little above the end, wrapped the handle end with black plastic electrical tape. It's non-magnetic and works great.
Threads: 112
City: Medford OR (OR what?)
Here is an excerpt from an ARRL manual:
http://www.arrl.org/files/file/Technolog...504028.pdf page 2
So even though iron (ferrous metal) is not used, brass will also detune an inductor.
Russ
