Philco ~ 1942 meets 2009 ~
Something to do with that extra console in the basement ? http://www.youtube.com/watch?v=z4WBTaz4NvY
Not sure if Home Radios is the right category for this, but here it is.
....no comment. Icon_neutral
I used to have a pirate Apple II motherboard, pwr supply, and 2 floppy drives mounted in an old IBM Selectric case. I also put a WE touchtone keypad and network inside a Kellogg wall phone, with cloth covered wiring of course. However, I hope that techno-nerd made sure the chassis went to a good home to enable someone else's console to work as designed.
Dave
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 332 online users. [Complete List]
» 1 Member(s) | 331 Guest(s)
