89-123 Coil DC resistance questions
Hi everyone!  I, also, am restoring an 89-123.  Fortunately I restored the cabinet first, in anticipation of a potentially brutal electronics restoration --and so far that resto has met my expectations.  The speaker field coil was open (I will rewind it).  The detector coil (7) is open (both windings).  Hopefully I can figure out how to re-wind that.
I have questions about the DC resistance of the antenna transformer (2) and the 2nd IF xfmr (20):  The print specs the antenna xfmr at 16.5 pri and 9 sec.  My primary is 24 ohms (secondary matches the spec).  Does that likely indicate a problem?  Similarly, the print specs the primary of the 2nd IF xfmr at 69 ohms, and the secondary at 84 ohms.  On mine, the primary is 99 ohms and the secondary is 117 ohms.  I've read that the DC resistance isn't very telling, so maybe these values are okay?  I'll appreciate any new information.
Regards,
Dion
Typically when the coils a bad your looking at a resistance that is much higher than the noted value. Like X10 or X100 higher. Wouldn't worry over a few ohms.
Thanks, Terry! I suspected as much, but don't have enough experience to be sure. Maybe you could indulge me by answering another question: Do you know what the gauge of wire is for the detector coil? Is it the same for primary and secondary? Is there a spec for the number of turns for each? As an alternative, can I just calculate the length of wire needed to get the specified resistance for each winding? -Dion
I think that the coil info for the 89/19 is around somewhere. Ron may have the definitive answer for you. Have be told it's 38G.
Welcome to the Phorum!
Icon_wave
Thanks again, Terry, and thank you, Bob, for the welcome.  -Dion
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
