1939 Zenith metal covers for auto-tuning adjustment holes
I have a 1939 Zenith 5-S-319 with racetrack dial and need the little metal covers that cover the adjustment holes for the automatic tuning. Several 1939 Zeniths use these. Pushbuttons are available as reproductions, does anyone know of a source for the covers? Thanks for any help!
Grainger or McMaster-Carr carry round metal hole plugs in various sizes. I'm sure you can find a size that fits and spray paint them if need be.
Both companies are on-line:
http://www.grainger.com
http://www.mcmaster.com
Chuck
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 419 online users. [Complete List]
» 2 Member(s) | 417 Guest(s)
