  • 1 Vote(s) - 4 Average
38-3 Magnetic Tuning part workaround
I'm sure a lot of others have come up against this issue in working on a magnetic tuning system.  There is a very small plastic piece that insulates the spring contact on the bottom in this picture from the shaft.  Without that piece, the radio is silent.  When that spring is depressed by the magnetic tuning dial yoke, it cuts out volume as you go around the dial to your preset station.
So...
No one apparently makes a replacement for the piece in question, shown second from bottom.
I took a bit of 3/4 inch heat shrink tubing and cut it to the proper width using my broken piece as a pattern.
Then I asked the wife if I could borrow her hair drier....
A few passes, testing for fit in-between, and the cut piece of heat shrink slides snugly onto the magnetic tuning shaft.
The heat shrink is shown third from bottom
Finally, don't forget to put in the  fiberboard insulator (shown at the top) on the side of the spring contact facing you before you put the whole thing back together again!
Good workaround.
But in the worst case this whole thing can be removed, so, ok, you have to listen to some radio tuning sound for 1 second while you depress the handle and rotate it into the place.
Not entirely awful.
This feature is icing upon the icing upon the cake Icon_smile
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
