1929 highboy cabinet door pulls
I have a model 87 highboy (not deluxe highboy with the disappearing doors) with broken door pulls. I found an unbroken pair of door pulls, but I'm not sure they are correct. My cabinet does not have exposed screws on the back side of the cabinet doors. I'm guessing that a coarsely threaded screw is mounted on the front of each door and somehow securely fastened, and then the door pull threads onto the screw. In Ron Ramirez' book, Philco 1928-1942, it appears this pull was used on models 40,65,76, and 95 as well. It doesn't look like this pull was used on any other model year of production.
How do I safely remove the broken door pulls without cracking the wood? Do I use a pair of lock pliers? Do I turn the pulls in a counterclockwise direction? Thanks for your assistance.
Jim Skelly
Hi Jim
That is odd. I once junked a Model 95 highboy that was in very bad condition. Its door pulls had exposed screws on the inside of each door. I think I still have them around here somewhere...but I have no idea where since my recent move.
I'm afraid I can't offer any suggestions here. You might try carefully turning one of the handles counterclockwise, but don't force it. If anything seems odd, STOP right away before anything is harmed.
Perhaps someone else will chime in with suggestions.
I recently acquired a model 87 with one broken (and loose) door pull. I was able to unscrew it. The door has a hold bored in the front not all the way through that holds a metal disk with a hole in the middle that traps a screw in the center of the hole. The pull threads onto the end of the screw and tightens down on the front of the door. It is a standard right hand thread. I don't have the screw in-hand at the moment, so I can't tell you the exact size and thread (or whether it is a modern size and thread). My disk has come loose and no long properly traps the screw, so I am planning to pull it out and set it back in, probably using hide-glue to hold both the disk and screw.
If anyone has a spare set of door pulls for this radio, I would love to hear from you. I will be searching...
If anyone is looking for replacement door pulls or handles I suggest looking in a large supplier of architectural salvage, as it is possible that Philco bought pulls off the shelf. I am fortunate to have one locally - you may have seen them on the TV show "Salvage Dawgs."
Great suggestion, thanks!
Photos help a lot.
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
