Smoother tone for the 16B
The 16B code 121 uses a tone control that adds .003mfd at each position to the right it clicks. The first position open with no connections to the caps. There is a pretty drastic difference between the 1st and 2nd positions. 1st is very bright and 2nd is kinda muffled. It's a bit of a pain to take the tone switch apart to change the value of the caps so by adding a resistor in series with the 1st .003 cap you can lessen the effect of the 2nd position. I ended up using a 120K resistor. Makes a smoother transition between the 1st and 2nd positions doesn't sound anywhere as near as muffled.
Another option is to substitute a pot for the switch, along with adding the appropriate circuitry. I think Philco used these switches because they could make them in house, and they were therefore, cheaper, or because it was a way to avoid paying royalties to RCA, or some other outside firm, with the same result.
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
