Philco PT 29 line resistor
Sounds like you have a short some where. Did you measure the line current? Heaters should be drawing about 150ma. Not sure what you mean by ground lug of 35Z3. I don't believe any of these resistors should be grounded. Do you mean the plate? Have you tested the tubes?
Here is how I wired it. I made sure when I took the old resistor off I kept the wires connected to the lugs together. I have not tested the tubes yet.
Thoughts ?
That does not look correct. I believe the 35Z3 plate (pin 2) should connect between the two resistors.
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
