Philco 91x??
Need some help identifying the chassis that was in a cabinet  that I found at a yard sale.
From the research I did on Philco Radio Galley the cabinet is either a June 1932 91X or possibly a Fall 1932 71X, since the chassis I have has eight tubes and the 71X is listed as 7 tubes I have ruled this model out.
I went to Nostalgia Air and printed the schematic for Philco 91 ( attached)  this schematic doesn't appear to match the chassis I have. The most notable difference is the schematic only shows two Electrolytic Cond. items 57 and 55.  You can see from the attached picture I have three cans.   Next difference this is  that the  attached schematic has 9 tubes.
I Have attached a picture if the cabinet, front and back pictures of the chassis and a copy of the schematic.
Any help with this identification would be greatly appreciated.
Also the chassis doesn't have any identifying marking that would help.
Try a model 43.
That's one big power transformer, must be a 25 cycle set.
M R Radios   C M Tubes
It's definitely not a model 91, a model 91 is basically laid out like a model 90, but with 6.3 volt tubes rather then the 2.5 volt AC ones.
As Terry said, probably a 43.
43 Schematic
43X
When you get it all cleaned up shoot a pic of it over to Nathan so we can add it to the Gallery. As it stands now we haven't one now and it would be a help. Tnx!
Thanks for the help. When I'm done i will send pictures . The cabinets does have 80 years of dents and dings
philco predicta
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
There are currently 1480 online users. [Complete List]
» 1 Member(s) | 1479 Guest(s)
