Source for Mono Crystal/Ceramic Cart.?
Other than scrounging through used stuff, Does anybody have a source for KNOWN GOOD or NEW ceramic or crystal cartridges for old phonographs? Not interested in playing the E-Pay lottery Icon_rolleyes . Reasonable prices would be good too.
Pardon me while I go back to scrounging.
It is getting to the point that I feel negligent for not dealing with phono combos:
https://www.russoldradios.com/blog/mega-...f-tomorrow
Russ
You can get a very nice ceramic cartridge replacement from voice of music :
https://www.thevoiceofmusic.com/catalog/...es=Crystal
I ordered one to try out.
Had an account with them already.
Russ
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
There are currently 1165 online users. [Complete List]
» 1 Member(s) | 1164 Guest(s)
