Chassis protection for a 650
I got stuck on this project it's waiting for more ambition. Can't seem to make the trim pieces for the front and corners.
I wanted some protection for the chassis.  The idea is to keep the cabinet as small as possible including the speaker.
On the face   The space on the left of the cardboard strips is for the speaker grille. I wanted to use the little speaker that is on top, But I couldn't bring myself to separate the original one.  I noticed that the output transformer has different taps for the speaker coil. I should be able to match the impedance close enough to run the small one. The big one can just go for the ride.
The strips are to be wood trim. The steel plate that holds the big speaker has a hole in it.
I found the display window on ebay.  Did I get the right one?  The shadow meter window was blocked so I used scotch tape for the meter display screen. That's why it's white in color.
I think some green tint might look good. Make it look like an eye tube.  And it's off center again.
It was tricky getting all those little arrows to line up with the dial.
Here's the link to the electronics thread      https://philcoradio.com/phorum/showthread.php?tid=19767
Value of capacitor
What is an OP?  Looks like the “OP” mistakenly typed electrolytic.  Lets forgive him.Joe Rossi — 06:31 PM
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
