Threads: 13
City: Clemmons
State, Province, Country: NC
The early sets used grid hookup 11 strand 'impregnated' wires (green cloth) with (it seems) an inner wrap of cloth under the outer. Do these offer any sort of shielding? Has anyone ever noticed a big difference when using a newer plastic coated stranded wire, aluminum - Chinese or whatever? Curious of others experience. I read in a old radio service publication which said that a shielded grid wire with one end grounded would certainly help on some radios. Not really sure what the Philco catalogs (looking at '37 parts catalog) mean by 'impregnated'.
Threads: 270
The only cloth covered shielded I can recall used in early Philcos is black. It's used between the line bypass bakelite block and the off/on switch. The shield is grounded to limit the ac hum pick up from the ac line as it passes by the low level audio stages.
Now I think I've got it!
(This post was last modified: 04-30-2021, 08:24 PM by
Radioroslyn.)
The regular wire, if you do not see the mesh or a drain wire soldered to the braid (which is easily discerned even under the cloth, and that wire is much fatter) is not shielded.
Threads: 27
City: Tehachapi. California
Personally I like my wires virgin.
[Image:
http://philcoradio.com/phorum/images/smi...on_eek.gif] Chris
This is what happens when you do not shield them.
They get impregnated.
